deckofficer
Banned
Well, today the hydralic throw out bearing actuator puked and left me without being able to disengage the clutch. No problem as I can easily shift without using the clutch and if I get caught at a stop light, just slide to neutral, stop, turn off engine, put in 1st gear, and when the light turns green, hit the starter. But since the future upgrade to the T56 Magnum 6 speed would require a new hydralic clutch servo, the time has come NOW to swap the trans, so this failure won't cost me any additional bucks over the cost of the swap. First issue was measuring the driveshaft that will have to shortened to accomadate the longer T56. My yoke to driveshaft angles are already a little larger than preferred and shortening the driveshaft will increase those angles. I'm researching going to a CV joint to replace either or both of my u-joints. Does anyone have any thoughts on this?
Thanks,
Bob
Thanks,
Bob
