LumenAl
As you may know, my T is a late 60's build and I need a part machined that I can't find anywhere... My T has a VW steering box and the steering arm has a 25MM ball on it. The steering link has a "tube" if you will that attaches to the 25MM ball on the steering arm. Inside this tube are two bushings that grab each side of the ball and is held in with a plug that screws into the back of the tube and has large carter pin to secure.
Here is a drawing of the part I need done... (2 each), all dimensions are in Millimeters. (Top View should say Front View)
here is a 3D view... (not good at 3D but you get the idea I hope).
The hole that goes through is what allows the grease to travel to the ball on the steering arm...
So, hopefully I've been able to communicate what needs to be machined, anyone got the skills and tools? (I sure as heck don't)! I'm not looking for a freebie, am very willing to pay.
