TRoadster
First let me say Hi y'all.  I would post first on the Intro Threads but for some reason I can't post there but I can post here.  So I'll post there once I can. I need some advice on what stall to choose when I buy a new converter.  I've read everything I can find and I still have questions.  I know with the light weight T bucket the stall numbers will be lower than stated for that converter.(up to 1/3)  I also know that my high torque at low rpm motor will make up some of that differance.  So here is what I have... a 1967 Buick 430(factory rated at 475ftlbs torque at 3200 RPMs) mostly stock so those numbers should be close if not a little low.  9" rear with 3 to 1 gear.  26.8" rear tires.(She's a Track T).  Rebuilt transmission(heavy duty clutch plates, etc).  I'm looking at 2200-2800 or a 2800-3200 stall.  The lower may put me around 1800 to 2000 rpms .  My 430 puts out as much if not more torque at 2000 rpms than most mild sbcs at peak.  I think the higher one would put stall around 2300 to 2500 rpms.  I'm leaning towards the higher one but... I can't make up my mind with the information I have. Any suggestion on what stall I should get?  I need some help... advice... something.  By the way, I've heard good things about Boss Hogs converters so I may go with them.
