one finger john
For second I thought that was a connected bat room.Gerry, I especially like the "high-tech" paper towel holder! grin.
Wife was all for it. She knows how much I love this stuff. Garage is 8.0 ft by 18.0 ft. Its not wide enough to open a car door once you have it inside . Thats how they mostly build em over here. Its built into the house so I can get into it from the entrance hall. Mind you I had to cut a doorway to do it
Happily I have most of what I need from my engineering past, and the seller threw in a live center in the buying price, along with a chuck for the tailstock. One thing I have invested in is a new set of Indexable tip tools, which have come down in price over the years.
Gerry
Gerry,
I don't know if you would need my help, but for 15 years I sold carbide cutting tools for a major supplier. I also taught carbide failure analysis and how to select the proper speeds & feeds according to the mat'l being cut & the grade of carbide being used. I would be glad to help if needed.
Spike
All help is welcome. I have bought a set of tip tools. When they get here I will post a pic. Your advice on cutting speeds would be great as my 'knowledge' is mostly with HSS ones. Oh I dont have coolant which I understand you should used with tip tools.
Gerry
I mostly turn SS MS and brass. Lathe is set on lower speed range for more torque (we all love torque). Its variable speed between 100 and 1000 rpm.
G
Thanks Spike. Now I have the basics as a starting point. Not too hard to calculate where I should be for speed n feed. I have some tips for alloy at work. Got them to refinish pump faces and they are just awesome. They look like polished black chrome and cut like I ve never seen. Hope one of my new tools will have the same fitting so I can 'borrow' one!!!
G
