T4TWO
Ok, A friendly but informative disscussion about "open diff's" vs one with a "posi" in your humble opinion.
Pro's and Con's of either types of rear ends?
Which would you install and why?
What size gearing would you install and why?
I'll start by saying that my build came with an open diff and I'm not sure what size the gears are in there now. Because I haven't got to that part of my build yet. But, I have always liked and had/have posi rear ends in my current/past Hot Rods. Anywhere from 4.10 to 5.36 gearing. My first hot rod had 30" tall slicks and I needed the 5.36 gears to turn them and get me down the 1/4 mile at 12 flat, + the car weigh a ton. One of my current street/strip cars doesn't weigh a ton (about 3400 lbs) and I have 28" tall slicks for her. So I opted for the 4.10 gears moving me through the traps about the low to mid 13 second range. Our other race car (about 2600 lbs) has 4.88 gears on a mini spool to move her down the quarter at 10 flat.
Recently I was able to pick up a used but reconditioned 3rd member with posi for my 56 pumpkin rear end. Gears in there are a 5.375 ratio. A bit large for my taste. But with 33" tall tires and a overdrive trans. I should be able to tame her down a bit and still cruise around all day on a tank of gas.
I know these cars are lite and do not require much. But curious as to what you peeps have in your ride and why you chose to go that route.
