westmichguy
I am looking for info on mounting the pickup bed to the body. This is a Speedway setup and the bed bolts to the body and then the outside of the bed is blended to the rear of the body. Mine has cracked on both sides of the outside, while the mounting looks ok. The previous owner said this was from no support at the rear of the bed and he added to L-brackets to help support it. I am ok with repairing the fiberglass and blending it back in if ned be, however I would like to know if the should be more bracing for the bed and if so what should it look like. I am sure that the rear tire size and stiff suspension amplifies this problem.
Thanks,
Gil
Thanks,
Gil
