I'm thinking about this breather: http://02e449d.netsolstores.com/38nptrearendbreathers.aspxHow did you set up the breather for the rear end? Haven't done mine yet. Still thinking about it. What gears did you get?
Yes, that's helpful, thanks for your reply. My question was poorly worded, what I actually needed was axle flange to axle flange actual which you provided.
I intend to use 61.5" Jag rear end narrowed to 56.5" and planning on 4.5" offset wheels. Body clearance will be about the same as yours. Clearance is reduced somewhat as Jag suspension compresses but still appears adequate based on test fitting done with 4.0" offset wheel.
Again, thanks for your help.
Jerry
