couple of my pics of my frame and little cap i machined to top the vertical piecesI used 7/8 round stock and cut a 5/16 slot. the one inch for me gets a bit big. To avoid using the rubber gasket on the edge i sat the glass in the frame on some oring materal then filled the void with windshield black silicone from both sides . So the silicone not only fills the sides but also goes under the glass and make a very nice seal. I used 1/4 glass from a mall door double safety and slight tint.
Windshield is installed. Siliconed and bolted. Mirrors are on. I pulled the carpet up, with plans to cut the sides off the transmission hump. The hump is a bunch larger than it needs to be and the gas pedal is on top of the hump. I will take some pics of the windshield and the floor board.
