Lee_in_KC
Got the rock screen mounted in the grill shell, thanks to Rooster. Used his construction adhesive idea. Changed out the blue and red AN fittings for nickel-plated. Looks much better with the flames. Got the steering box and front end back on. Mounted the shock towers and headlight stands. Dis-assembled and cleaned the carbs and re-set the floats. How do floats get out adjustment? I re-set them when I first got them... they were quite a bit off from the factory (Edelbrock). They were off again when I pulled them apart. I don't see how they can change on their own. Got all the brake lines cleaned and painted and re-installed. Got a new master cylinder to replace the crappy rebuild I had. Bled the brakes since it is easier to do with the body off. Man I love speed bleeders. Took a whole 15 minutes to bleed all four corners. Got everything on the frame under the body done, then put the body back on. Woohoo! Getting close.
![053109Progress002.jpg](/proxy.php?image=http%3A%2F%2Fwww.nationaltbucketalliance.com%2Fbbsimages%2FT05-1716%2F053109Progress002.jpg&hash=ddf24c848c4600718511fc5567b1a948)
![053109Progress004.jpg](/proxy.php?image=http%3A%2F%2Fwww.nationaltbucketalliance.com%2Fbbsimages%2FT05-1716%2F053109Progress004.jpg&hash=46d0f9d9c5fdd81e0dd6b5004f2ec6dc)
![053109Progress006.jpg](/proxy.php?image=http%3A%2F%2Fwww.nationaltbucketalliance.com%2Fbbsimages%2FT05-1716%2F053109Progress006.jpg&hash=0d5e0e2bbd7115b29739fb16b94df2a9)
![053109Progress010.jpg](/proxy.php?image=http%3A%2F%2Fwww.nationaltbucketalliance.com%2Fbbsimages%2FT05-1716%2F053109Progress010.jpg&hash=6013b4aa6c9d8f5e08f8751d0584b7d1)
![053109Progress014.jpg](/proxy.php?image=http%3A%2F%2Fwww.nationaltbucketalliance.com%2Fbbsimages%2FT05-1716%2F053109Progress014.jpg&hash=ab13ad9763d9a2114dcba57267c9ed41)
