Time for the long-overdue update!
We're closing on on it fast.  I'm happy to say that chassis is 100% complete and ready to go.  In the last month or three, we've gotten the drivetrain completely finished as well.  The wiring is 99% complete (only the license plate lights to wire), the plumbing is 100% complete, the M/C is mounted, pedal works, and the brakes have had a preliminary bleed. The steering column is completely fabricated, the shaft is done and everything steers and works properly.  the windshield frame was fabricated from 7/8" solid aluminum we milled and has been put together.  The dash panel is done and painted and the gauges done  (photos do not show the dash installed).  the latest hurdle we accomplished was modifying and making the shifter linkage.
Instead of taking the easy (read $$) way out on the shifter, we picked up a rusted and frozen early mustang shifter at the swap meet for $10.  We blasted, cleaned ,rebushed, trimmed the mounting and then whacked the handle off and welded an extension made from 5/8" chrome moly bent in more of a swan shape.  We then had to remake the cable within and make sure it still operated properly.  Once we had the operation working properly, we made custom linkage to connect the ford shifter to the Chevy T350.  After a little adjustment, it works properly and we have about $15 invested + our time.
We still have the emergency brake and the gas pedal to mount, as well as mounting the windshield frame and getting glass cut.
We'll be starting it this next week and if all goes well, perhaps driving it some next weekend!  The plan is to get it mechanically sound and wrapped up this month, then pull the body off of it for paint this winter.  Hopefully, we'll get it into upholstery by early January.  The goal is to have it done to be put in our booth at the Indy World of Wheels in February.
Hare are a few pics I took today:
