radiator help
akitagandy
I'm looking for ideas on mounting this radiator (24"x19") the frame is 26 1/2" wide so it will have to go on top of the frame
My frame is 23 1/2 wide, so I had to design a bracket to the frame as well as a 1 /3/4 raise so the lower radiator hose would clear the second member, that supports the rear bars of my torsion bar set-up. I used 1/4" plate and welded a straight up and down z. I then tapped two bolts into the frame with two springs on each side, and a single bolt on the radiator mount. Blow up my avitar. It might work for you also.
I have a Griffin crossflow in mine. I made a U shaped support for the bottom and lined it with rubber pads. Then the radiator cover has the same type thing welded inside it. So that the radiator is sandwiched in rubber.
