EX JUNK
Moderator
Here is another easy project. Go to your friendly home improvement store and check out the plumbing section, the plated drain pipe section in particular. You can get straight or 90 degree bent pieces of plated brass drain pipe. With some regular pieces of radiator hose you can create a custom hose set up for your car.
Here are a couple of pictures of how I used it on my car to give you some ideas.
