Radiator sizes
barnbikes
Does anybody know of a website that lists Radiator sizes?
I have a radiator off of a old Hobart Welder and I want to put a modern radiator inside the cast iron frame.
Thanks
Thanks
Search -"car radiators custom built "and contact several of the businesses listed and do the build based on the housing you want to use and the engine you are going to use. Yes it will cost more than a stock unit that may be a close fit and may not cool the car. You will get a radiator that fits and cools your car. This is one area that you only want to do one time and do it right.
Al
There are several sites on E-bay that sell aftermarket Aluminum radiators, a few that I looked at gave all the dimentions for the car that they replaced. Most are in the sellers on-line store.........ruggs
Try this one Jam-N-Motorsports also my new Speedway Race and Oval track catalog has alot of radiators with the sizes........ruggs
Thanks
Does it go in a hotrod or the welder? Cast iron frame suggests welder.
Chesters' How To Build A T For $3,000 lists some sizes along with the top and bottom hose outlet size. It's probably not needed but the trans cooler size is listed also. What size space do you have to fill?
