Rip VW
Ok I ran into a problem with locating my Vega Steering box. In order to make things fit and correctly installed it seems I would need a Pittman arm that is raised about 2 inches and it seems like there is no 2" raised arms out there available. I have a flat arm but to get the drag link parallel at ride height I need something that is raised 2 inches. I can't move the steering box because it interferes with the motor mount so that is out. I can't bend my flat arm as that would in effect shorten the arm and I lose some steering travel. I can get a 2 inch drop arm but you can NOT flip the arm because of the pitman shaft splines are tapered and won't have complete engagement. I did see a 1" raised arm through P&J's. I need at least 2" and at $112.00 a copy I would rather find what I need before paying so much for an arm that may or may not do the job?
So let me ask all the vega cross steer experts and non experts how is your Pittman arm set up and how is your axle setup. My front axle is a 4" dropped SuperBell with 4 link suspension and of course my frame is a 32 Ford Style frame using the dropped front crossmember so the axle is closer to the center of the frame than usual and my tie rods are attached to dropped steering arms to clear the 4 links.
Let me know how you are set up..
