Indycars
I seem to have an unusual rear wheel cylinder for my drum brakes. The seals say they
are 31/32", but I cannot find such an animal. I can find 15/16" and one time I did find
some 1.0" kits/cyl for my Ford 9" SMALL axle bearing rear axle. I've searched on the
Wagner FC-19000, but don't find any related 31/32" parts. I bought and have confirmed
they fit, Fel-Pro 55035 axle flange gaskets. Also the axle bearing are Timken RW207CCRA.
Can anyone point me to correct wheel cylinder repair kit ???
Bore Diameter (in.): 1.378 in.
Outer Diameter (in.): 2.835 in.
Width (in.): 0.845 in
Below is all the info I have from my original components.
This first image is a composite of two photos showing how I took image below.
I'm using a eye loupe that provides 8x power magnification. Since there are so many old
guys, figured you might need the help. LOL !
I hate to replace my wheel cylinder when it says "Made in USA". Since I'm into the rear
axle replacing the gear oil and cleaning the housing, I wanted make sure the brakes were
the best they could be.
Ford 9" Gear Oil Replacement and Cleaning the Interior of the Housing
If I can't find a good replacement, then my old seals look good and I will just go back
together with new DOT5 fluid.
