Neshkoro
I've been having trouble with the front brakes on my T Bucket. It seems that lately (since last year) the right front wheel locks up when I step on the brakes. I've tried adjusting each front brake until there is a little drag on each drum. I've tried backing off the right brake adjustment. The brakes are drum brakes circa. 1952 Ford. The front wheel cylinders are new as of last year. I changed them when the problem started. The pedal is solid; not spongy.
The rear brakes are '68 Nova drums. The master cylinder is a single cylinder circa 1967. For years it was OK. I even went as far as pulling off the drums and with a caliper adjusting the shoes to be the same size. Each drum ID is close to the same the same size.
Any immediate thoughts?
Thanks,
Bill
Thanks,
Bill
