Don'tCallMeJimmie
Ugh.
I have finally gotten my life back together enough to retrieve my project from storage and what do I discover?My never-run, 'fresh' from the rebuilder TH350 input shaft and stator shaft splines are heavily rust-encrusted and now look like they've spent the last 3 years under water.
I'm trashed from moving everything the last weekend, so I've not looked at them more than in passing, but I don't think they are saveable.
Research says the input shaft is simple enough to find, either OEM or beefed up aftermarket. But, it seems the stator shaft is only available with as an entire front pump assembly or with the pump rear plate, aka the stator plate attached. Either are about the same outlay.
Makes me wanna abandon the '350 and consider a 700r4 core and benchtop rebuild for about the same outlay. Or am I thinking about this all wrong?
Opinions accepted with grace and appreciation. Pictures soon, but don't hold yer breath.
