Flatsman
Thanks Railroad for your input, I believe you are tight with the wb being a tool and all, it does come down to the sotp. You mention your combo with the 600, I would be willing to bet this avenger carb has a puny pv restriction channel, I'll know when I pull the primary metering block off. These avengers were Holley's answer to some of the more universal carbs they offer being so rich out of the box and have been very well known to be lean on most all instances, I may be speculating wrong here though. I have thee black spring in the seconday vacuum , so they dont offer a stiffer one Im told. Im banking on the flat spot being still in the primary, would explain why the secondary jets are 10 sizes over just to get a 12.5to1 af. stock were 68 and I put some 80s in there![]()
What language are you Guys speaking??? You are way out of my league!
