Unless you're wanting drum brakes for a style issue, I would go with disc brakes.
I have a 1999 S-10 rear under mine and used drums because I wanted an early look( also used drums up front). Here is what I learned and some issues that I had.
I had read that GM had rear brake lockup problems on the S-10 and basically down-graded them to control it. I tend to believe that story.
First, they're pretty small at 7.5". Seems undersized for a truck.
Second, I don't think mine had ever been changed and had metallic brake shoes. They might be more fade resistant than organic linings, but they need more force to work well.
Third, and probably the worst issue is the 3/4" bore wheel cylinders. This is considerably smaller than most master cylinders and actually reduce the force transferred to the shoes.
Looks to me like GM intended for all the braking to be done with the front discs and only wanted the rears to work when the truck was loaded and pedal pressure (and line pressure)was very high.
I had front brake locking problems when I first got my car on the road. The fronts would lock and the rears did not appear to be doing anything at all. I modified some larger wheel cylinders and went to organic shoes, but while the braking got better, it still wasn't good. I finally went to a twin master cylinder/ balance bar setup to eliminate it.
The new setup allowed me to run a small bore master cylinder on the rear brakes and get the line pressure up. The car stopped much, much easier and shorter with all 4 corners working.
If you still want to go with drums, I would go with a late 90's rearend. The earlier brakes had wheel cylinders that pretty much on fit only those brakes. The later rearends have unique cylinders too, but will interchange with Astro van cylinders. The van pieces are 7/8" bore. I used modified 15/16" 1982 Caprice wheel cylinders, but had to make new pistons and turn down the body to fit.
The shoes I used were the cheapest S-10 replacements from Orielly's. They did not appear to have any metallic content. I'm pretty sure they were straight organic.
You could also look at swapping larger brakes from another GM rearend.
Sorry for the long post, but I hope some of this helps.
Mike
