bigfrank330
Hi need some help here
The motor I had needs too much work
I have a chance to get a 880 Block that is in great condition
Besides the one piece rear seal and the fuel pump shaft hole not being drilled
Is there any diference between the 70's 350 and this 95-2000 350 block ??
I have a cam , lifters , timing gear set and heads to put on it
Going to use a dual quad set up w/edelbrock carbs regulated to 5 psi fuel pressure
Will a non roller cam work in this motor??
I would appreciate all your advice
Frank
Frank
