I have a7.5 rear end out of a Malibu. It's shocks mount under the axle. I plan on building a ccr chassis. Can I run this set up or will I have to make new shock mOunts for the top of exile axle Thank you.
Check the width on that to make sure that it will look good with your body. Usually those rears are very wide relative to a T body and they end up looking a little strange. Also be very careful welding on those axle tubes. It doesn't take much to warp them out of shape. S10 rears are perfect for the application and usually can be had for cheap
It sounds like the perfect rear for you then. Most guys just cut off all the existing mounts from the modern axles and weld on whatever they need. I don't know what the rear looks like so it's hard to tell if you can use the existing mounts or not. Some pics would help. It also depends on what suspension you are using. Coil-over, transverse leaf?
I want to use coil over. Not sure for link or ladder bars with pan hard Barr? Here's a rear shot of the rear end....... never mind I can not seam to get the upload to work right?
