flatheadgary
I found this on another site a few years ago and thought you all might find this handy.
I made mine out of .125 thick tubing but it might be better out of 3/16th, just in case you want to bend thick springs. I used 3"x3" for the base and 2"x3" for the legs. it is pretty simple to make. I measured the width of the jack and added a couple more inches on each side. Simple draw the ark of the spring on something, put the spring in and jack it up. Just use the ark you drew as a guide to see how much to bend it. A warning, DO NOT+++ I REPEAT+++ DO NOT USE HEAT!!!. You will be surprised at how easily it bends. I used it to bend the spring in the pick to have a reversed eye on one end and a regular one on the other. I took it to a swap meet where I was selling some stuff, just to see what people would say. It was the hit of the place. It seemed like everybody who saw it wanted to buy it or see it work. you can put it in a vise or just by itself as it pushes against itself.
