Yep, motorcycle steering dampers. Adjustable. Really helps with R&P.What are the two black cylinders on each side fwd of rack linkage? Dampers??
Here's my R&P:
It's in the front crossmember, with a steering shaft running back along the inside of the frame rail to a double U-joint to the column. If you like, I can dig out some more detail pics and post them.
Sweet Thanks bro.And I replaced the rod end with a beefier one:
Need closer picture but it looks like early Ford from your picture.
