OK I've grown tired of this set up. It's just not safe feeling to me. The shaft goes to the steering box with two set screws to keep it from pulling off then the middle of the column is supported by a bearing that has a set screw on it and a bracket that goes to the floor. I've got the bottom secure so that you can't pull it apart but the bearing in the middle and the bracket keep coming loose making the column very floppy. Is there another way to secure this? Am I better switching to another set up all together? If so what's out there and how much do I have to reengineer this for it to work?
		 or check my MySpace pics.. Good move... and good luck, this should not take very long at all, and you will be much happier...
	 PS, no U joints will be needed if you mount the box LAST...
