Arizona Desert
My t bucket seems to be all over the road except when I get past 50 Any suggestions? Just got car. My first Rod.
THANK U trying to find local shop in Casa Grande or Maricopa AZ that can be trusted enough to do this worekFrontend shimmy is caused by a number of things.
The combination of worn out components and or frontend alignment will cause serious problems.
First and foremost, the components that make up the steering assembly must be in good condition. These components are:
Tierod ends
Heim Joints
King Pins and bushings
Steering links
Drag link
Radius rods
Pittman arm
Steering box bushings
Hub bearings
Shackle bushings
All of these components must be in good condition. Replace any part which shows wear, or movement beyond design specifications. If in doubt, replace it.
Assuming all of your components are OK, the next step is to align the frontend. If your T Bucket has bias ply tires then you should have a maximum of 1/8" toe in. Radials should be "0" to 1/8" toe out maximum.
The final step, (and VERY important) is to balance the complete rotating assembly! Attempt to balance your tires mounted on the hubs if possible. If this option is not available to you, then balance the components separately. Your drums or rotors and tires must be accurately balanced!
Tire inflation has been a subject of controversy for a very long time. But there is a basic starting point. For spoked wheels, (motorcycle type) start at MAXIMUM inflation. Generally 45/50 lbs. For all other tires, start at 28/32 lbs. Test your T on several road surfaces especially rough roads. Inflate or deflate your tires to minimize bouncing. You will always get some bouncing, but less is better. Make sure that both front tires have EXACTLY the same air pressure.
There is a big difference between shimmy and bounce! You need to avoid shimmy at all costs! This is a self induced harmonic which will destroy your whole frontend and possibly cause a serious accident. Shimmy starts when the rotating mass (tires, wheels, hubs, and rotors or drums) harmonics go into oscillation with the steering components(links, bushings, rods, and tie rods). They "push" against each other causing a violent back & fourth motion (Shimmy). Because this motion is self induced, it progresses until something breaks, or over come by an external force (IE: hit the brakes and slow down). It is imperative that your frontend be in absolutely perfect working order.
Have you ever rolled a tire around your garage, or down a street before? If you have, then you may recall how the surface governed the direction the tire rolled. This same condition exists on your T Bucket. To overcome this, a frontend alignment is setup to create an equal force on both front wheels. This effect is called "toe in" or "toe out". This equal force tends to overcome most road surfaces, making the frontend responsive to the drivers command. However, too much of either can create a new set of problems. Tire scuffing will be the first on the list. Then there is the problem of shimmy. Toe in tends to cause shimmy more than toe out. Zero toe in/toe out will virtually eliminate shimmy however your frontend will feel "loose". In other words, your car will walk back and forth while cruising. This effect is usually manageable, but annoying. Regardless which "toe" effect you need, limit the adjustment to a maximum of 1/8" The next adjustment available to you is "CASTER". This is the tilting of your king pin bosses. This caster effect tends to make your front wheels follow the centerline of the front axle. Caster is good for helping your T track straight. You always want the caster effect to "follow" your axle. You adjust your caster by adjusting the length of the UPPER clevises on your radius rods. Typically, about 5 degrees of caster is plenty, and in some cases 2 or 3 degrees is all thats required. Have you ever pushed a shopping cart around a grocery store, and noticed sometimes the front wheels shimmy? Thats way too much caster! So go easy on your caster adjustment. Finally, there is camber... you can't change it easily because it's built into the king pin bosses. However, as your king pin bushings wear out, you induce more camber. So check your king pins & bushings occasionally for wear.
From the NTBA
