OK, fill up your MC, then get your bleeding buddy to pump up the brakes 3 times and hold it down, -with or without good pedal. Crack your main line to your front brakes, just a little, AT THE MC and shut it. I always have the fella tell me when the pedal is on the floor, that way I can seal things before he says OK. Do it till theres a solid flow of fluid. Tell him to pump them up agian, bleed that same line, about 3 times, (Top off fluid) then move down the line to the split that goes to each wheel, bleed there, 3 times, or until solid stream, then off to each wheel cylinder.
Then start at the rear line to the MC, then on back. When you get to the proportionor valve, things might get better. Once you get the valve to center itself, and bleed on back.
I have a vacuum setup and I have a air setup to bleed brakes, but you know what? I always bleed them the old fashioned way, get almost all the air out, then I can use then. OR use them to get almost all the air out, then do them the old fashioned way.
If you try to get all this bled agian, and if theres anymore trouble, need to let us know what the bore dia. is for the MC, your line sizes, and then your wheel cylinder size. Do you have a Power Brake MC? It being a closed system, you should have a good solid pedal after bleeding. If you have a PBMC, it'll still be really firm, until you go to stop, then it'll take a lot of pedal pressure to stop. Then you can get a longer brake pedal or redo your leverage point, go with diff. size MC piston....it being a sealed system, if you get the air out, there should be a firm pedal. And yes, there are valves in your brake system.
Running a single chamber MC? Or a dual chamber? You have to have a proportioner valve to adjust things. I run a centering valve too, that way if the brake line accidently blows, it won't drain your MC, you'll either have your front brakes or your rear.
You should have your MC rod adjusted so you start getting pedal about 1" down from the top. After bleeding, you adjust it where you want it to be off the floor.
Don't get frustrated, take a break, then come back to it.
