Tail Light Upgrade
Indycars
In 2015 when everything was coming together at the same time (Engine & Trans)
money was a little more scarce, but now it's time to go back and upgrade certain
aspects of the car.
I've always been concerned about people seeing me from behind, especially
during the day when my small tail lights just didn't show up very well.
I think the car will be seen now. The lights are dual faced and at first I didn't
want the second side, but figured I could black-out the amber side. Now I'm
thinking it might be a good thing, it should light up the back of car for better
visibility at night. Looks like I might need to move the license plate over some.
The old lights cost $30 for the pair, the new lights were $100 for the pair.
Both are LED.
https://www.etrailer.com/Trailer-Lights/Optronics/STL52ARB.html
Those look sweet, thanls for including the link . . . turns out e-trailer takes PayPal so I popped for 3, (always good to have a spare) of these complete with rubber mounting boots, wires, and stainless look plastic trim rings
Fusion LED Trailer Tail Light - Stop, Tail, Turn, Backup - Submersible - Oval - Red/Clear Lens Optronics Trailer Lights STL211RB (etrailer.com)
I need the backup light component along with stop/turn/tail and the boot mounting looks like it will work with the shape of the '27 back end below the rear deck lid.
I'll post a couple pics and my impression of the overall quality once they get here . . . almost anything has ti be better than the el-cheapo replica '32's that came with my car kit.
Those look sweet, thanks for including
I always try to include links or part numbers to the components I'm using, supper glad it finally
paid off !!!
Do you have to include back-up lights to be legal in the islands. I did have a tag light, but removed
it since the amber/back side of the lights should provide more than enough light.
Got tired of the cheap Amazon turn lights I had in the front, so I went to a Kawasaki motorcycle
shop in OKC and bought 2 lights for $125. Only because I thought they would be quality and I
could start thinking about other projects.
To continue from the paragraph above .....
The turn signal has an eyebrow that can be rotated 360° to fit any orientation needed.
paid off !!!
I'm sure if I don't have backup lights it'll be something I needed to have . . .it's one of the things, like e-brake, they never fail to check at annual inspection.
It's one of the reasons I got the Lokar shift boot/ gear selection indicator kit . . . the decoder box has an output for backup lights and park/neutral start interlock.
Turn signals look sweet as well, and the finish looks first rate.
You can never too too careful !
Indy, I think we have the same valve covers:
ACtC-3cdBJeEB4LlZjzRpKBKICY2AKMx4SiyQj0ZiB3rNlJ0KXzgl7mwbaaa22XwcEWQuGbjS2H-FA95qxQ_VZ1MefeMFA85f1DQAkJ_BLQZz437dZy7MVE8q7rBfgDDo3DfVPzJkagJkij6OMNMPIojdi_n=w1474-h941-no
I painted the top halves black.
I saw those right away too. They're cool.
Where did you guys get'em?
Great minds think alike !!!
You can get them at Summit and probably Jegs also.
https://www.summitracing.com/search?SortBy=BestKeywordMatch&SortOrder=Ascending&keyword=PRO-141-915
They really work nice when adjusting the valves. I added a piece aluminum flat bar 1-1/2" wide
to cover the rocker on the pushrod side. I attached it where the top would have been. I have a stud
girdle now and it still works for adjusting the valves.
Why ..... thank you !!!
Just one more photo ..... kinda ?
Decided to use a Deutsch DTM 3 pin connector this time. Last time they were hard wired.
I bought these kits in both Deutsch DT and DTM sizes. DTM is the miniature connectors, so
can only handle 7.5 amps. Enough for tail lights and my dash wiring.
I bought my own crimper, therefore the kits below are w/o a crimper.
Deutsch DTM
DTM Gray Installer Kit - WireCare.com
Deutsch DT
DT, Installer Kit w/o Crimper, Gray - WireCare.com
Wow, That is nice but $250 seems to be excessive for tail light plugs. Does that kit include different plugs to wire the rest of the car too?
Check out the link. But here is the contents of one kit. Includes multiple connectors
from 2, 3, 4, 6, 8 and 12 pin conductors, see below.
Deutsch Kits
Genuine Deutsch DT Series connectors, ranging in size from 2 to 12 contacts, including Sealing Plugs, Extraction Tool and assorted Mounting Brackets in a strong steel divider case with plenty of room for additional products. The DT Series kits are an ideal way to quickly stock up on the most common and widely used Deutsch DT connector system products, and to have an on-hand connector assortment for a variety of harness construction and repair needs. This DT Series Kit is available without the HDT-48-00 crimping tool, and with black plugs and receptacles.
Kit Includes:
  • 20 - 0413-204-2005 Sealing Plug Contact Size 20
  • 25 - 0460-010-20141 DTM Series Solid Pin, Nickel 16-18
  • 50 - 0460-202-20141 Solid Pin Size 20, 20 AWG Nickel
  • 25 - 0462-005-20141 DTM Series Socket Solid Nickel 16-18
  • 50 - 0462-201-20141 Solid Socket Size 20, 20AWG Nickel
  • 5 - 1011-026-0205 DT Mounting Clip (Gray)
  • 1 - DTM Series Kit Instruct Booklet
  • 1 - DT-RT1 DT Contact Wedgelock Removal Tool
  • 2 - DTM04-08PA DTM Receptacle 8 Way B Key
  • 2 - DTM04-12PA DTM Receptacle 12 Way B Key
  • 4 - DTM04-2P DTM Receptacle 2 Way (Gray)
  • 4 - DTM04-3P DTM Receptacle 3 Way (Gray)
  • 3 - DTM04-4P DTM Receptacle 4 Way (Gray)
  • 3 - DTM04-6P DTM Receptacle 6 Way (Gray)
  • 2 - DTM06-08SA DTM Plug 8 Way B Key
  • 2 - DTM06-12SA DTM Plug 12 Way B Key
  • 4 - DTM06-2S DTM Plug 2 Way (Gray)
  • 4 - DTM06-3S DTM Plug 3 Way (Gray)
  • 3 - DTM06-4S DTM Plug 4 Way (Gray)
  • 3 - DTM06-6S DTM Plug 6 Way (Gray)
  • 2 - WM-12P DTM, 12 Way Receptacle Lock Orange
  • 2 - WM-12S DTM, 12 Way Plug Lock Orange
  • 4 - WM-2P DTM, 2 Way Recept. Lock Orange
  • 4 - WM-2S DTM, Lock, 2 Way Plug Orange
  • 4 - WM-3P DTM, 3 Way Recept. Lock Orange
  • 1 - WM-3S DTM, 3 Way Plug Lock, Orange
  • 3 - WM-4P DT, Mini 4 Way Recept. Lock Orange
  • 3 - WM-4S DT,Mini 4 Way Plug Lock Orange
  • 3 - WM-6P DT, Mini 6 Way Recept. Lock Orange
  • 3 - WM-6S DT, Mini 6 Way Plug Lock Orange
  • 2 - WM-8P Lock, DTM, 8 Way Receptacle Orange
  • 2 - WM-8SDTM, 8 Way Plug, Lock Orange
  • 1 - 109-95 Deutsch DT Kit Steel Cabinet
Did you change something? I swear all that info didn’t come up when I checked it last time!
I changed the lights to something bigger and brighter, then used the Deutsch connector
instead of hard wiring the lights.
Unless you paged down, you would not have seen the extra info.
