TH350 unidentified part
Albatross1953
I'm rebuilding a 1972 TH350. It's been a few decades since I had one apart. There is a weird looking clip that was lying inside behind the read clutch pack. I don't see it in any diagrams. Pic is attached. There were also 3 little black balls (approx 1/4") rolling around. They look a little large for valve body check balls. Can anybody point me in the right direction.
Since your are rebuilding your trans, have you thought about going to an overdrive trans like the 200-4R. It's over drive is 0.67:1 . Same size and uses the same driveshaft. The mount location is different.
I'm doing it for a friend. He's rebuilding a '72 Skylark from the frame up.
