Wellllll, it's become painfully obvious that building the car I want is beyond my grasp. Since I was a kid I've been in love with the old bobtail style Ts like Tweedy Pie and others.
But I wanted to build one with a twist....making it a low as possible. I have serious and deteriorating mobility issues, and I wanted to make it as easy getting in and out of as possible. Also I wanted the improved handling from the lower center of gravity.
Another feature I was hoping for was to use a cool 1920 Hupmobile grille shell, mounted intact just ahead of the front axle, kind of like this.
Another unusual feature was I wanted to use an old fox body Mustang racing suspension in the rear.
On top of all that I need the vehicle to be trailer hitch friendly, to pull my power chair trailer.
As it turned out, accomplishing these and other features I wanted would require an unusual custom built frame that is beyond my means...so it's time to change gears.
This time I'm starting my plans with a shortened version of RPM's standard frame, to get the bobtail short wheelbase. It's looking like adapting the Mustang suspension components will not be too hard. The down side it looks like the the lowness and the forward mounted radiator and Hupmobile shell are casualties.
The only way I can figure to use the shell would be cutting off the bottom, as is frequently done with 32 shells on buckets...but I just can't bring myself to cut up an intact and straight piece of 94 year old rarity. As an alternative, I have an already cut on Speedway Sprint style nose and grille...which was what I was planning to use before I found the old Hupmobile shell.
To help with the mobility ingress/egress issues I've decided to use airbags instead of coil-overs in the rear. This way I can make it "kneel" on the bump-stops about 3" for getting in and out, and raising for driving. Additionally the bags give me adjustability for trailer pulling.
Sooooo...here's where this mouse's next generation of plans stand....
Good? Bad? Ugly? Take up stamp collecting?
