The Gap Between The Bed and Body ..................
Joe-405
I have marine epoxied the bed to the body and bolted it for safety. Now i need to know what you guys use to fill the "gap" between the 2 pieces. I did make a groove in it before mating the 2 together. And will use a triangular circular sanding bit to make it uniform before filling it.
Do i need bondo hair or regular bondo or ???
Ok this is where i was confused................. Do i sand just the top layer off or go all the way to the fiberglass ?
ON fiberglass bodies isnt there 3 layers..............
1. fiberglass
2. body filler
3. gel coat for the top layer
Generally , outer layer is gel coat , inner is resin&glass fiber=fiberglass . Sand off the gelcoat & a LITTLE f'bglass, then cut your mat [couple layers should be enough] and imbed it w/resin in the area you're repairing [ don't use too much resin , just enough to saturate the mat] after that kicks , scuff w/ some 80 grit & finish shape w filler [bondo]. when you get it smoothed out , prime & paint !
Keep in mind that ANY exposed glass fiber must be covered w/ filler before you prime , otherwise ,in time it will show through your paint .
Same for "kitty hair" filler , it must be buried [which is why I don't like it !]
I dont have enough room to cover the fibers. If i sand it off it will be gone ! Can i just fill it with filler then ?
I dont pay attention to Doctors much. lol i got bored and i did not go over my weight limit doing what i was doing so i finished the mating ritual between body and bed !
for those wondering what i used....................................
DURAGLAS®
Duraglas® Fiberglass Filled Filler. Duraglas® body filler is the original fiberglass reinforced automotive body repair filler. Formulated with short-strand fiberglass fibers, Duraglas provides ultimate strength and durability on rust-outs, holes, tears and cracks. Ideal for use on metal and fiberglass panels.
  • #1 Short-strand fiberglass filled body filler
  • Reinforced for superior strength
  • Use with fiberglass cloth for large repairs
  • Rustproof. Waterproof.
