I tries to post this lastnight, but we were having a rain storm and satellite reception was bad, so heres the post....I just pasted and copied......
Yep....VB is right...won't hurt....matter for fact...it helps. Usually when we build a car, we do the motor and trans together. Alot of folks put the Stall Converter in as a piece of performance equip. A std. converter even benefits.
When you change them out or have your trans. rebuilt, this thing is dry. When you start the motor for the first time, the front pump has to pull fluid from the pan, thru the trans parts,(valve body included), and fill the torque converter.
This thing is spinning around with a heavy impellar in it, connected to the engine, trying to drive the front pump, and the impellar shaft has been spinning some with no lubrication on the brass thrust bearings and front support bushing, etc, etc,....see where I'm going with this?
Then, after running the motor some, you have to shift thru the gears several times to get the car to move. Your essentially priming the clutches and valvebody doing this. Usually when we redo a trans., we hook the thing up to a big electric motor and run it a little....that way we're not throwing a bunch of horses to a dry, vulnerable trans....
Its best to have all the components filled with fluid and operated a little before trying to move a 3500+ pound car or truck. A light bucket....its a little different....but still....theres wear and possible heating of hardened parts that could cause annealing, possibly even drawing down of the parts, causing premature wear.....
