Ted, I don't think it's a fire storm at all. It's just a situation of technology doesn't wait around for anyone and we all have to fight to keep up.
Every single car in the world has a very specific spot around which the the entire car will balance. This spot is not identical on all cars and changes with things like the driver's weight. But this spot, known as the center of gravity (CG), is always there. We cannot deny its existence, agreed?
Next. No matter the type of car, its rear suspension will pivot around a specific point. But (and this is important), the point around which the suspension pivots is not necessarily the same point where the given rear suspension is going to apply power (or lift, if you prefer to use that term). Are we still in agreement, here?
The point where the given rear suspension applies power is what we call Instant Center (IC). Different suspensions and even different suspension components will change the placement of IC, agreed? In other words, IC is the center of an arc created as the suspension links move. On a car equipped with a ladder bar (or, again, a lift bar, if you prefer), it is dead simple to identify IC. The center of the bolt attaching the front rod end of a ladder bar is the point of IC. It's right there, visible to the human eye, agreed? If the car uses leaf springs without any other traction device, IC is located at the center of the front spring eye. Agreed?
But if the car uses rear coils and upper and lower control arms, then IC has to be calculated, as there is no way for you to see the theoretical intersection point between the upper and lower links. Agreed?
We can take a scale drawing of the car and plot that intersection point, by extending the lines created by the upper and lower links. This drawing will then give us the IC point, agreed?
But here is where you're going to have to start sketching and thinking as we go. If we draw a horizontal line through the CG and then draw a vertical line through the front spindle, we will create another intersection point. Still with me on this one? Now, we're going to draw yet another line, from the centerline of the rear tire contact patch through the intersection of the CG and spindle lines. This last line is called our neutral line and is sometimes called a 100% anti-squat line.
With those ladder (or lift) bars, the relationship between IC and the 100% anti-squat line will always be the same. Agreed? It cannot change, because the front mounting point of those bars is fixed.
Now, you can start to see what happens with an adjustable 4 link suspension. By moving the mounting location of the upper and lower 4 link bars, I can put IC anywhere I want. I can put IC directly on the 100% anti-squat line. Or I can put IC above it or below it. Still with me, here?
If I position IC at any point below that 100% anti-squat line, when I hit the gas, the car is going to squat and hit the tires in a softer manner. On the other hand, if I move IC above the 100% anti-squat line, the rear of the car will rise on acceleration, hitting the tires harder. Which brings us to the possibility of placing IC directly on the 100% anti-squat line. With that adjustment, the rear of the car will remain neutral on acceleration.
OK, think about how the upper and lower control arms are positioned on a car rolling off the assembly line. If we extended the lines from those links forward to an intersecting point, that point is going to generally fall well forward of the front bumper. That means our IC is way down below the 100% anti-squat line. Stand on the gas and what happens? The rear of the car will squat. Remember when all the Chevelle guys had to have those old Lakewood upper control arms for their cars? They worked a treat, because they raised the rear locating point of the upper control arms by a couple inches, moving the IC point back in the car and getting it above the 100% anti-squat line. Now, the rear of the car would rise on acceleration, sticking the tire harder.
So, if we want to plant the tire, we want that IC to be as high as we can get it above the 100% anti-squat line, don't we? Absolutely not!
And you thought you had a real good handle on all this, didn't you? Well, you've forgotten the fact that we are going to reach a point where the cars has moved far enough that all our "lifting leverage" is gone. Then what happens?
As the car starts returning to a neutral height, our instant center starts dropping. Quickly. And those tires we planted so hard are now going to unload and spin. So we can't try to take too much off the table, because we're going to be required to put it all back and that's what catches us up.
But wait, what is all this talk about upward and downward body movement? If I'm sitting at a light and stab the throttle, do I want the rear of my body to move up or move down?
NEITHER!! I want the car moving forward. I'm not trying to move up. I'm not trying to move down. I'm trying to move forward. I want to apply the least amount of downforce to the rear tires that I can get away with. Every thousandth of a second the body is going up and the sidewall of the tire is wrinkling from the additional weight placed on it is just another thousandth of a second that the car is sitting static and not moving forward. And the more body separation I achieve at the exact moment of acceleration is going to come back to haunt me by unloading the tires that much more within the first 30 feet of motion.
A car sitting at rest has 100% rear tire traction. The guy that is going to move his car the most efficiently is the guy that can keep that percentage as close to 100% as possible, whilst moving the car in a forward direction. So I want a car set up with Instant Center falling at a point just ahead of the Center of Gravity and just above the 100% anti-squat line, which will raise the nose of the car. Then I can limit front suspension travel so the front end cannot raise much more than an inch or two. Now I am working the rear tire of the car as hard as I can work it, but I am also using the torque reaction of the rear end to push the car forward. The finish line is in front of you, not above you or below you. It can take a lot to sort what length the upper and lower links should be and where the mounts for each end should be, in order to achieve the sweet spot.
In a dragster with no rear suspension, you can change rear weight percentages with adjustments to front tire pressure and by raising or lowering the front motor plate. Ever notice where the crank centerline ended up on some of the old Fuel Altereds? Look at some old photos of the Pure Hell car for a drastic example.
Maybe this will clear up all the misunderstanding on how a triangulated, 4 link suspension works.
(OK, Ron, so I lied! :rofl
