EX JUNK
Moderator
Jim , I'm sure you meant to say that a 4-link does not affect Caster like a hairpin setup does , camber is set by the axle.
You are correct, Dave. It's hell getting old and having these "senior moments". LOL
You are exactly right. Many years ago, I put some spring clothes pins on the shafts of the front shocks on the Silver bucket. It moved down less than 1" in normal driving.I'll add this , under real world driving ,your frt suspension likely will only travel + or - 1/2 "-3/4" , in other words you'll never feel it.
seeing that my pay grade is probably a negative number, I was lost at X...LOLZandoz , Learn about "sprung weight & spring rating" . X amount of force produces Y amount of movement , then factor in the tires deflection characteristics & the dampener [shocks] effect on all of it . Way above my pay grade , but experience tells me what does what . Best I can do.
How's that for a B.S. answer
Suspension(str axle)theory tells us that ONE link for every action you are trying to control. So for that one needs a radious rod on the right side to keep that side fron going foward and back and you need one on the left side to keep that end from going foward and back. You will need just one more (either side) paralell to the other to keep the axle from rotating(maintaining caster).
Yes, and its the same set-up as 99.9% of all the Sprint cars racingWould that be the same as a 4 bar setup with one bar removed?
