First , thank you ! That's about what I expected, I know the heads don't really start flowing till .500 lift , so I'm guessing in order to see any " real" gains , I'd have to go with a hydraulic roller for lift and duration , somewhere in the 250 @ . .050 and .600 lift ...
In my day , no self respecting drag racer would be caught dead with a converter, almost as bad on the street ( although not having to shift on a date did have its perks , but, depending on the girl , sometimes shifting did too !!)...
I hope you don't think that. We're just a bunch of old guys wishing we were young again!
I remember my dad's 57 Chevy with bench seats. There were a couple of good right hand turns you could take at speed, which we used to refer to as "slide-over, date" corners!![]()
That's how I remember them. SOB's.They were called SOB's (slide over baby) by most of the guys I dated, . . . back in the day
Looks like we all have many very fond memories of our youth. . . . . . Many of which were related to automobiles.
Back to this , after some thinking , I'm surprised that the dual plane didn't make more power earlier in the rpm range than the TR , conventional wisdom says you loose bottom end grunt with a TR , doesn't appear to be the case here??Sim03 is run with the Weiand Stealth intake manifold and 750 cfm carburetor.
It's not an obvious choice for me when given just a intake manifold model. I have four choices
to pick from, Sim03 is run with the Standard Flow option for dual plane manifolds. There are two
more options that flow more. If I go with the next one above Standard Flow, the High Flow, the
difference is about another 10-15 HP, not earth shaddering.
The HP, Torque and RPM scales are the same for every sim posted so far.
Below is information about the assumptions that Dynomation is using.
>>> Sim03_StealthDualPlane750cfm.dxml <<<
Filling/Emptying Wave-Assisted Model Run ----------------------------------------
Approximate Intake Dimensions Used In FE Simulation ----------------------
Intake Port Minimum Port Area: 1.67 Sqin, 42.4 Sqmm
Intake Port Maximum Port Area: 4.20 Sqin, 106.8 Sqmm
Intake Runner Length: 14.00 In, 355.6 mm
Approximate Exhaust Dimensions Used In FE Simulation ----------------------
Exhaust Port Minimum Port Area: 1.34 Sqin, 34.1 Sqmm
Prmary Length: 38.30 In, 972.8 mm
Prmary Diameter: 1.76 In, 44.7 mm
First Collector Length: 16.60 In, 421.6 mm
First Collector DIamater: 3.25 In, 82.5 mm
Number of integration cycles run for convergence: 2
Simulation elapsed time: 78:920 ms
Where I came from they were known a COD, "Come Over Dear".They were called SOB's (slide over baby) by most of the guys I dated, . . . back in the day
Keep in mind that it's a Street tunnel ram manifold that you have and is rated for 3500-7500 rpm. It'sI'm surprised that the dual plane didn't make more power earlier in the rpm range than the TR , conventional wisdom says you loose bottom end grunt with a TR , doesn't appear to be the case here??
