Didn't mean to try to fly over any heads. In an automotive application, its handy to think of electrical loads as current, Amps, because thats how we choose the correct conductor (wire) size. However, electrical work is performed by Power, expressed as Watts, and calculated as Volts X Amps.
Electrical work can happen where you don't want it, like in the fan switch example here the Watts appear as heat only, and the work they do is to burn up the switch.
Another example would be a too small starter cable, where instead of most of the electrical work being done in the starter motor, un unacceptable proportion of the work is done in heating up the cable and the power (Watts) is lost to the starter motor.
Whenever electrical work is done, useful evidence is voltage drop. In the case of the starter cable above, with your voltmeter connected to the battery +ve and the starter motor terminal, you can read the volt drop in the cable when cranking, which tells you how much power (Watts) is being lost in the cable.
