If ya have a crate engine and ya don't have a water pump or pulleys or anything at all, does it matter if a long water pump or a short water pump is used? I'm leaning toward using an electric fan sp I'm thinking it wouldn't matter.
The closer to the engine, the less leverage on bearings or bushings, plus the whole assembly is shorter, I think it looks a bit more compact/together... but it is still a personal choice...
If I recall correctly, the c-c of the ports is the same on both the short and long pumps. The two are only about 1 5/8" different in projection. Either should work fine, but the short would probably be better for clearance purposes. I hope this helps...
I'm totally with Ted! if you gotta go to the fan, go with a spacer up to 4 inches. If any longer, go with longer pump or move the radiator some....short pumps are best....depends on looks though, and application.
Somewhere in The History of the World Part II, I think I mentioned I bought a high volume aluminum water pump from.... oh, never mind, we'll Skip that.
The pump to block ports of this high volume pump are smaller than a stock pump. I can open up the ports/passages within several minutes with a die grinder. The issue is the claim of being high volume... let's see, the velocity and pressure change can be calculated, but............... why bother.
