TDitty
I bought the Speedway 49-54 mr roadster modified spindles speedway says they are a direct fit for the mustang II disc brake set up Which I also have but here is my problem the outer wheel bearing seems fine but the inner seems sloppy on the axle when using mustang II bearings does anyone know what inner bearing you use or is the slop normal (I am figuring no). I called speed way and of coourse the techs are only in mon-fri so no help there. I need some help here or I am gonna give speedy B a punch in the junk.
Russ
Russ
