Is anybody running a vette rear end in a Bucket? pros/cons? fit? I know you can use a jag but out of my $.
Is anybody running a vette rear end in a Bucket? pros/cons? fit? I know you can use a jag but out of my $$.
I'm running a Corvette rear end in my T-Bucket.
Pros:
Nice ride.
Looks really cool watching the chromed axles spinnin' as it rolls down the road.
Cons:
Expensive to work on.
Hub has to be pressed on and off to replace the rear wheel bearings(cost me $325 for one side and i had a hard time finding a shop locally that could do it) because the bearings must be shimmed to prevent excessive run out. If the run out on the rotors is excessive the calipers pistons will oscillate causing the pistons to suck in air resulting in a loss of brakes. If the car spends alot of time parked the pistons will corrode causing the calipers to leak. They can be honed out and have stainless steel sleeves and O rings installed to prevents leaks and corrosion.
If the side yoke (inner axle) ends get worn it cause excessive rear tire wear and positrac clutch chatter. The axle shifts can move back and forth and can cause a form of rear bump steer.
Did i mention expensive to work on?
My T-Bucket already had the Corvette rear end when i bought it. If had of known all the cons of the Corvette rear end i would have passed on the car.
What year is the rear end in your car?
I also prefer the ride over a solid rear. I use the Jag, but I'm sure if you don't care if it is a bit ugly, there is an IRS in the 90's Thunderbirds which has to be cheap at the auto bone yard.
These can be had for super cheap at most pull a part type auto wreckers and they were available in cougars as well. The newer Explorers also have an IRS along with a boat load of other cars now a days. The Fords use an 8.8 which has a large selection of support parts and they are quite strong.
Check out http://www.team321.com/
Off the line at full-throttle with a 500+ hp 6-71-blown 355 SBC, Jag IRS with no posi-traction...Traction is not found in the IRS units, plain and simple...
