Is it a stroker motor? If so, internal or externally balanced? Your build sheet should provide that info. If it's not stroked, or a 400sb, that 383/400 flex plate is your problem. You are also right to question the balancer, if it's a smooth, stock, balancer, that sounds like a internal balanced 350 balancer. The stock 400 balancer is big, but has a part cut out of it, unless it's an aftermarket balancer. If you have a mismatched flex plate and balancer, that's a problem, also is the flex plate on the right way? They will bolt on either way and depending on the starter, may even run that way, I found out the hard way on that little nugget. I not sure that the converter would bolt up to an externally balanced flex plate if it was backwards, but the flex plate weight should face the block. From your description, it sounds exactly like what mine did with the wrong flywheel on it. If that's the case, you definitely shouldn't run it till it's right. It's possible someone just mixed up the flex plates before you got it, disconnecting the converter and running it for a minute will tell the tale about it being a engine issue or not. Your builder questioning the converter tells me he thinks it's a balance issue.Yeah I'm putting back on stands tommorow
So this engine was not balanced then, when it left the builders?Well guys as it turns out it was just the wrong flex plate. The weight was in the wrong place truck runs fine.
Thank you for all the help.
