Banjo fittings
Track-T
I need a source for 1/2 x 20 banjo bolts and fittings.
Been looking at Earls...arrowquip and others, They have the 7/16x20 fittings but nobody seems to have the
1/2 x 20. I'm trying to use them on my master cyl. because of clearance problem with the hood.
pic. does'nt show too much,but this is what I'm working with
thanks guys, looks like pure choice is the one.
Various AMC cars from the 70's used a similar style master cylinder, but with the lines to the inside.
Worth considering if someone else is using a firewall mount and needs some clearance.
You will need to do some internet homework to determine bore diameter of the various versions but that shouldn't be too hard on NAPAONLINE.com and the like.
