clamper
I have just replaced all four wheel cylinders (T has been parked for about ten years or more). Now I can't get them to bleed. The rears still had fluid to them prior to new cylinders, the fronts showed no sign of fluid. I filled the master cylinder and tried to bleed, first I opened all bleeders and let it set with the master cylinder full, after couple of hours I closed all bleeders (no sign of fluid).
The wife and I started to bleed one wheel at a time, still could not get any fluid to the wheel cylinders. The master cylinder is a corvair and is mounted up behind the dash. Anyone have any ideas???
