I did the floor, I layered reinforcing glas from floor to sides by overlapping each layer like an inch wider than the previous, then reinforced the inside sides with glass. If you plan on functioning doors, plan now. I also boxed the rockers underneath and reinforced the cowl, fore and aft of doors, seat riser, and rear of body under seat with steel all routed into and encased with glass. There are as many ways to do it as there are people doing it... I would suggest reviewing numerous build threads and fiberglass articals, then decide what best suits your build.Do you guys reinforce the inner body with wood before you start putting fiberglass mat on the floor?
The glass and mat are next.I'm trying to see what you've done . If the only thing you used to attach the floor is the adhesive ( no cloth or matte ) then you' re destined to fail . You need to sand the adhesive a smooth then glass over the joints w/ either cloth or matte & resin usually about 2" either side of the joint ...
The strength is in the mat. There are various types and weights on the mat also. Seriously, do some research before jumping into it. I learned a lot about it in the process of my build by reading others ideas and on line stuff. A good selection of various glass mat rollers, etc will make things go smoother too. eBay was my friend for all related supplies. Look at choppinzechs build thread... he is a very talented and knowledgeable glass guy.The glass and mat are next.
Use MAT and not cloth, mat is more flexible, able to form around curves while being bent 90* MORE EASILY . Did you use laminating resin or the waxed resin? Laminating resin just needs to be clean, it should be tacky if not, it's probably waxed. The body is probably waxed resin, so clean, ruff sand, clean again. Seen pics of a few T accidents with the frame and floor still attached but the body is a few yards down the road. Don't be afraid to lap the seam with some wide mat tape.The glass and mat are next.
I have an electric winch on my ceiling....I never thought of that.When I'm on the floor, I put the chain hook on a belt loop.....then I can pull myself up off the garage floor with the chain hoist.
spanky, what movie was that screen cap from?
