California Custom Roadsters ... CCRDoes anyone make a body with a floor allready installed. Is starting without the floor the best way to start the mock up.
We have the 10" stretch body that has the door in it. We can make it all work for you.Does anyone make a body with a floor allready installed. Is starting without the floor the best way to start the mock up.
Every thing cost more today. Do all bodys have a lip on the bottom that the plywood sits on from the inside of the body.I thought everbody made them with and without a floor. It just cost more.
Yes and no. Most bodies have a bottom edge in them. You can mount the floor to that, but it won't channel the body. Most people want to channel the body 3" so that the bottom of the body is even with the bottom of the frame rails. In this case the floor will get glassed to the sides of the body.Every thing cost more today. Do all bodys have a lip on the bottom that the plywood sits on from the inside of the body.
CCR's Bodies come with the Floors installed, actually they are not installed. They are all one piece laminated body and floor in the molds then the Coremat is laid down and another layer of 3/16"glass is put on over that. This ends up being a 1/2" thick floorboard, and solid...plus you will never need to worry that the floor will break loose from the body.
View attachment 7993View attachment 7994
