Welcome to Our Community
Sign Up
Dismiss Notice
Brake lines and master cylinder
Discussion in 'Brakes' started by tbucketlar1, Jan 23, 2017.
  1. tbucketlar1
    tbucketlar1
    Expand Collapse
    Jul 2, 2016
    35
    0
    Gender:
    Male
    I have a total performance bucket I need new master cylinder. On my old Mc I took the check valve out for disk on front and left check valve in for drums in rear. I get new Mc and it comes with no check valves in it. I need to have at least one for rear drums like cannot find any.The valve looks like a small spring with a cap on one end it is about 1/2inch long.So now that I don't have any check valve in the mastercylinder can I just put a 2 pound residual valve in the disk brake line and a 10 residual valve in the drum brake line or do I have used proportioning valvery in the drum line. I prefer not to use proportion valve if possible. My master cylinder is below floor. Thank you Lar
  2. Spanky
    Expand Collapse
    Jul 29, 2016
    3,088
    2,530
    Gender:
    Male
    I know guys that run dual MC'c with no RPV's and no adj prop valves here in St Louis and seem to have no problems. I don't use the RPV's with mine, but I found that it stops more controllably with an adj prop valve on the rears. Just sayin . . . :)
  3. 409T
    409T
    Expand Collapse
    Moderator
    Staff Member
    Jan 16, 2009
    1,803
    560
    Gender:
    Male
    Occupation:
    Retired
    You can do it the way you suggested. Just out of curiosity, have you tried not putting in any residual valves or proportioning valve? It seems to me that if you ask 10 different people which if any of those items are necessary you will get 12 different answers.
    lincolnuT likes this.
  4. lincolnuT
    lincolnuT
    Expand Collapse
    Mar 21, 2008
    1,835
    485
    Gender:
    Male
    Occupation:
    Retired
    I will be one of those 10 and my take is I don't use either with no problems in the last 25,000 miles with Rear Drums and front Disk.......Now with the right size MC on my Disk/Disk set up it is good to go....
  5. tbucketlar1
    tbucketlar1
    Expand Collapse
    Jul 2, 2016
    35
    0
    Gender:
    Male
    I will try with no residual or proportion and see how that does very carefullyrics and if any problem I will install purport. valve on rear. I never had any valve for front disk anyway. If anyone else has any information I will gladly to hear. Thank you
  6. old round fart
    old round fart
    Expand Collapse
    Feb 5, 2008
    3,239
    1,197
    Gender:
    Male
    Occupation:
    Retired
    For what it's worth Spirit puts the prop. valve in the front system. The valve cuts down pressure and you have smaller tires and close to the same weight. Makes sense to me.
    fletcherson likes this.
  7. tbucketlar1
    tbucketlar1
    Expand Collapse
    Jul 2, 2016
    35
    0
    Gender:
    Male
    Spanking what proportion valve did you use in case I go that Way? Thank you
  8. fletcherson
    fletcherson
    Expand Collapse
    Nov 7, 2014
    2,902
    921
    I wondered about that.
  9. Spanky
    Expand Collapse
    Jul 29, 2016
    3,088
    2,530
    Gender:
    Male
    I used the Speedway purple one. Easy to install & adjust!:)
  10. hulkamania
    hulkamania
    Expand Collapse
    Sponsor
    Forum Sponsor
    Mar 6, 2008
    596
    136
    Gender:
    Male
    Occupation:
    Sales Manager
    We run a wildwood porp. valve and do not run residual valves. We have done this setup since we have started.
  11. tbucketlar1
    tbucketlar1
    Expand Collapse
    Jul 2, 2016
    35
    0
    Gender:
    Male
    I probably not do anything till next week, some other things need to be done around the house right now. Thanks for help any other comments are OK to let me know
  12. old round fart
    old round fart
    Expand Collapse
    Feb 5, 2008
    3,239
    1,197
    Gender:
    Male
    Occupation:
    Retired
    Josh, I notice you use name brand components (Super Bell, Wilwood etc.) That is why your kits have so much value. Good thinking!
Share This Page
SSL Certificate
