Welcome to Our Community
Sign Up
Dismiss Notice
Brake system for Hot Rods
Discussion in 'Brakes' started by T-Test, Dec 28, 2019.
  1. T-Test
    T-Test
    Expand Collapse
    Feb 6, 2009
    1,722
    932
    Gender:
    Male
    Occupation:
    Machinist/Welder/Mechanic
    There will ALWAYS be those that say different, but this is the BEST way to do it-----and remember it is a CLOSED system and if bled properly, it will stop you and not have the difficulties that some have.
  2. Dan the Man
    Dan the Man
    Expand Collapse
    Feb 4, 2019
    27
    4
    Gender:
    Male
    Occupation:
    Insurance Agent
    What is the reasoning for the Residual Pressure Valves?
  3. choppedtop
    choppedtop
    Expand Collapse
    Jan 10, 2014
    1,933
    637
    Gender:
    Male
    Occupation:
    Retired
    If the master cylinder is lower than slave cylinder and calipers, the is a chance that a cavity could be between the master and the slaves or calipers. If that happens you may have to pump the brakes more than you want to make a sudden stop.
  4. T-Test
    T-Test
    Expand Collapse
    Feb 6, 2009
    1,722
    932
    Gender:
    Male
    Occupation:
    As Choppedtop said, but you don't have to have them. BUT if the M/C is below the wheels and mounted onto the frame you SHOULD use them.
    All said and done, IF you bleed the system CORRECTLY, it doesn't matter as it is a CLOSED system.
    lincolnuT likes this.
  5. lincolnuT
    lincolnuT
    Expand Collapse
    Mar 21, 2008
    1,834
    485
    Gender:
    Male
    Occupation:
    Retired
    If the system is in good shape with no leaks then they are not needed (closed System) like T Test said.. They are just something that the suppliers sell to make money...….Do not use them cause it's a trying to solve an problem that should be addressed, ie there is air getting into the system no matter where the MC is located.
    409T likes this.
  6. old round fart
    old round fart
    Expand Collapse
    Feb 5, 2008
    3,239
    1,197
    Gender:
    Male
    Occupation:
    Retired
    I thought the 3lb. Was to keep the drum brake shoes from getting to far from the drums to let them start braking the same time as the disks.
  7. lincolnuT
    lincolnuT
    Expand Collapse
    Mar 21, 2008
    1,834
    485
    Gender:
    Male
    Occupation:
    Retired
    Just adjust the drum brakes as they wear down.....That will be sometimes a ways off...Again if the system is in good shape that is not needed...IMHO...….
  8. dwsatt21
    dwsatt21
    Expand Collapse
    Aug 7, 2015
    482
    219
    Gender:
    Male
    Next time I'll try out not using them. Just finished my brake system and they are already in it.
Share This Page
SSL Certificate
