Ok I have a Ford 302 HO out of a 95 Mustang GT so it's a roller motor with the pedastal mount roller rockers. Engine is rebuilt and pretty much stock except for an e303 cam 1.6 roller rockers and TFS upgrade valve spring kit. Engine shop set the valve height as per the cam card. I'm waiting on an adjustable push rod to get the correct length push rod but I thought I'd try checking the length with the stock push rods that came with the engine originally. I put the number 1 cylinder at TDC and both lifters are down. I put in a stock push rod for both the intake and exhaust and put on the rockers. I tightened them down by hand until I felt no play in the push rod and felt some resistence which would be zero lash. Correct? With my torque wrench set to 20ft lbs I get between 1/2 and 3/4's of a turn utnil I hit the 20ft lb's on the torque wrench. Does this sound like the stock length push rods will work? being I'm going a little past 1/2 a turn would that mean the push rods are to long or to short?
Thanks for the help!
