I have a question Jim.Can you use ceramic pads and shoes for all drums and discs?EX JUNK said:Don, if dusting is a real problem on your son's car, it would seem as though they are dragging too much and not completely releasing. Perhaps ceramic pads would help. My GMC Denali cam with ceramic from the factory and when I replaced the rears, the guy a NAPA gave me regular pads. What a mess they made on my wheels. I went back and complained and got the proper pads, which only cost $10 more, and the problem was cured.
Ted when i first got my car going the front brakes sqeeled like a stuck pig and got really hot i talked to Brian at Total and he said no need for the check valve in the front he said for 26 years they have been building them with out and no problems so i took the set screw out and removed the ball valve inside then reinstalled it have not had a problem since i also did it to Thomas's T and hes fine also.Just something to think about.I have the Dayton wires with the Wilwood '175'pucks in front on 3/8 in stainless rotors.And no probs.Also the brakes lock up big time with alittle peddle movement i have to push alittle harder than power but they get the job done.Ted Brown said:Somewhere I have a message from Bob of Power brake, He said the the 2 lb check valves, end up to be much more pressure at the pads, and that will keep way too much drag in the ft disk brake pads, that is bad in too many ways to let it go on, so there must be a cure for this??? I think we use them because the master is lower than the wheel cyls, I wonder if using a raised brake fluid fill container would cure that problem, like a VW has?
So you dont have to redo your lines just take the ball valve out of them then reinstall.Ted Brown said:Thanks Rick, I do have a smaller set of calipers that sounded like a Pig also, bet that was the problem all along with them, tried everything else to stop it, the one's I have on now are double cyl, and so the pressure is way less..but I am taking them off (valves) now to see how they work without the valves as I can't remember how it acted without them waaaay back when.. hehe CRS.. gettin sucks in the memory dept..
