I just noticed the input line... is that your concern? That should be a soft line, or have a coil in it.Looks pretty good. I doubt it will move that much. You could go under and around the front or go with braided line... I like the hard line setup, personally.
I was thinking the same thing. But it's the output from the pump, same line I reference in my post directly above.I just noticed the input line... is that your concern?
The line that has a 180° turn and then goes vertical. I would wrap it with some insulation, the header looks pretty close and will transmit considerable heat to the fuel line.
The input has room I’m not 100% sure that I need the rubber lm not against changing it up.I was thinking the same thing. But it's the output from the pump, same line I reference in my post directly above.
It's so short, no room for flexing.
Not at all. the only thing of real concern there is the positive terminal on the back of the alternator! If you've got plenty of clearance there, then you're goldenIt is tight on the block in the front would that be concerning?
You could try a different fitting out of the pump... like a 45*, 90*, or banjo, if you can source it. That way the line would be exiting in the general direction you need without having to put that bend in it, that’s taking up so much real estate.
Thank you! I appreciate everyone’s input. This is all new to me as far as a full build. I like to do my own thing. At times it works out and at times I learn.In general, I think you have it in good shape. The heat probably won’t be an issue in an open bay engine compartment, everything else looks good. My comment about having a soft line on the input was based on long term stress from vibration and flexing, as the engine and chassis are sort of independent and can move. It may never be an issue. It could cause a vibration noise, but it’s an easy fix if that time comes. Nice job!
I clocked my Fuel Pump About 180 degrees by taking the screws out of the split line. Then run a rubber line (hose) looped from the Hard line from the tank back to the inlet of the pump. Three o'clock position. Then run a Hose ( or hard line) to the carb of metal fuel filter at the manifold. The outlet is at the 1:30 or 2: o'clock position. I have polyurethane motor mounts from Speedway. They keep the mounts from sagging and the pump from hitting the frame.Thank you! I appreciate everyone’s input. This is all new to me as far as a full build. I like to do my own thing. At times it works out and at times I learn.
