Indycars
Thanks for asking Screaming Metal!
I still have not fired the engine yet, it's been done for quite awhile now thou . It was going in to fall of 2013 and not ready to start it, so I decided to go ahead with my plans for converting from the TH350 to an 200-4R overdrive trans over the winter. I've never been into a automatic trans before, so another adventure. Built with the book from CK Performance, which ended up being a big project by itself. Lots of machine work to convert every thrust washer (plastic and metal) to a torrington thrust bearing.
New transmission mount had to built and welded in by a good friend. Used the trans mount and incorporated a driveshaft loop.
Got the engine and trans installed in the chassis, but had clearance problems at the firewall, so I lowered the engine in front 1-3/4". That started the domino effect ...... mechanical fan is too low, change to electric fan, need high output alternator, need bigger wires to carry greater current, etc, etc.
I'm hoping for this March to get it running now, can't hardly wait. It's been 12 years since I have driven the car.
