Thanks George, You did it perfect... For those that have a narrow frame at the rear, it is easy to ad a new cross member close to the body, then cut the old narrow frame section off, make a wider new section (only if needed) so that everything will fit, but it all should fit in a pretty narrow frame, mine is 34" wide 31" ID That new complete mount can now even be the rear cross member if you like... the only other thing needed besides you you see there, is radius rods, mounted pretty much like the stock Jag had, only nice looking like a normal T Bucket radius rod, can be either a single rod or hairpin or?? your choice... Now it is mounted like it is supposed to be and will ride nice and quiet and smooth... Like I told George, I have 1 set of the springs made new to 1/2 of the stock springs strength, plus I drill that set of shocks, and drain out the fluid, so you now only have 2 shocks instead of 4, because of the much lighter weight of the T Bucket... Almost forgot, that rear tube would be 2x2" X .250 = 1/4" wall...
I will get off my soap box on this matter, from now on... I had wanted to make and sell that complete setup, at a price, kinda like RPM gets for his radius rods , etc. His prices are very hard to beat... Now I can sleep well at night... Thanks again George...
